Author Topic: electric window not working but sounds like it's trying to!!!!  (Read 1082 times)
Offline whit
when i operate the switch i can hear a noise like it's trying to work but nothing happens?
there is obviously power getting to the motor but i guess either the motor isn't working? (if it wasn't though would i hear a noise?)
or the motor is operating but something else is stopping the mechanism?
the noise is like a buzzing or whirring sound so it's sound like the motor is doing something?
Offline Len
You will need to change the window regulator
www.sas.org.uk
www.the-ace.org.uk
Offline JamesS
I had this with a mk2 regulator. Although the regulators are different the principles are the same. I found that the cables get gunked up with crap which prevents smooth & fast speeds. If you clean the cables while moving reg open closed and regrease this should help. I also took apart the internal mechanism and motor, cleaned and greased everything up again. Seemed to work a treat. Cheap non-VAG regs seem to play up quicker than a used working genuine parts. Mk3 lecky regs are probably more common than mk2 so may be worth just buying another one.
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
