Author Topic: no power above 3k  (Read 1588 times)
Offline TAZ-MAN
no power above 3k
« on: 21 May 2012, 09:11 »
Hi;
I am new to VAG ownership, I have just bought a V.cheap Golf 5-dr TDi with 138k showing on the clock, although its tatty it's a nice drive.  But lacks any power and is totally dead above 3,000 rpm.  It does not burn or loose oil or over-heat. So before I chopit in or scrap it is there anything l can check to regain its potental.  It would be a shame, as my wife does like it.
Re: no power above 3k
« Reply #1 on: 21 May 2012, 09:39 »
Could be a turbo fault, they are known for sticking vanes.
Offline TAZ-MAN
« Reply #2 on: 21 May 2012, 10:12 »
Yes, somebody else mentioned that!  Is it an easy fix? Cost?
« Reply #3 on: 21 May 2012, 10:21 »
Not an easy or cheap fix you will need to replce the turbo.
Might be best to start with the basics, is the fuel system clean (check and replace the filter), pump or cam timing timing maybe out.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 21 May 2012, 17:26 »
Correct me if im wrong, but assuming it is a MK3,  the TDI doesn't have VNT Vanes?
Still sounds like a boost issue though..
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline TAZ-MAN
« Reply #5 on: 22 May 2012, 08:08 »
Okay then, if it hadn't got variable vanes? will it be any cheaper. Coz at about £290 for a turbo I will be getting rid.  ASAP.
« Reply #6 on: 22 May 2012, 10:40 »
It might not be the turbo, as I said earlier, start with the basics.
