Author Topic: 16V MK3 IDLE VALVE  (Read 1576 times)
Offline kawabill
16V MK3 IDLE VALVE
« on: 08 June 2005, 23:34 »
Hello everyone having problem's with the idle stablistation valve my mates one has 12.3 volts when engine is hot my gti has only .5 volts if i take the electric part of and work the plunger by hand as someone starts the car everything is fine has anyone had this problem before  its now driving me nuts all help with thank's :cry:
Offline mk1
Re: 16V MK3 IDLE VALVE
« Reply #1 on: 11 June 2005, 10:08 »
Hi kawabill ,
Check fuse 15, you should have 12v at one of the terminals in the idle control valve plug(black wire). If you don't, check the wiring especially the multi plug on the engine harness. The other wire goes to the ECU which pulses the earth to regulate the idle speed. The idle valve should have a resistance of 3.5 to 5 ohms.
Steve.
Offline kawabill
« Reply #2 on: 12 June 2005, 10:41 »
Thank's Steve the wire was broken where it goes through the bulkhead to the ecu working fine now ta
Offline mk1
« Reply #3 on: 12 June 2005, 19:04 »
Good to hear it is fixed :smiley:,
Steve.
