Author Topic: Fixing my sun roof.  (Read 2191 times)
Offline ju571n
Re: Fixing my sun roof.
« Reply #10 on: 21 May 2012, 18:54 »
Mine is broken too, mine however is wedged up with two strategically placed pieces of wood to stop it sagging once moving over 30mph  :laugh:
Think the drains are bunged too as cornering results in showers for passenger/driver depending on direction.
  :rolleyes:
Offline stainesy
« Reply #11 on: 21 May 2012, 20:32 »
My broken side is wedged up with the case that holds the face of the stereo  :grin:
Offline Adezmk3
« Reply #12 on: 21 May 2012, 22:54 »
I've got a complete replacement working unit yours for £20 collected from Hinckley. Pm me if your interested? Cheers
Offline Greengolf
« Reply #13 on: 21 May 2012, 23:59 »
You remove the headlining - not difficult, but just need to remove visors, grab bars and pillar trims first before taking it out. Un couple the electric motor and the four drain pipes. Finally there are about 8 bolts that hold it attached to the roof. Once these are removed it should pretty much drop out - I did it on my own but easier with an extra pair of hands - if nothing else they can admire what a great job you've done. Then its just a case of putting the new one in.
Offline LowlifeDubber
« Reply #14 on: 22 May 2012, 07:54 »
Ive had mine in and out a few times now.My original one packed up with the same problem yours has.I ended up moving the silver slider with a flat blade screwdriver in time with the other side when putting the roof back down.
New sunroof in im afraid.Its a little bit of a pain but you will do it a piece of piss. :cool:
