Author Topic: Some Assistance...Bonnet Cable  (Read 1524 times)
Offline WadGTI
  • Golf GTI'er
« on: 20 May 2012, 16:24 »
Hi Folks,
Not sure really where to post this, but I have a 52 plate seat ibiza and the bonnent cable has snapped.
The cable has detatched from tthe handle underneath the dash. problem is seat stick to much plastic trim inside am not sure where to begin or where to start.
Any ideas if you are able to get into the lock by breaking the grill? or where the cable would run via the engine into the cockpit.
Any suggestions would be appricated.
Thanks
Offline Bellend
Re: Some Assistance...Bonnet Cable
« Reply #1 on: 20 May 2012, 16:36 »
If it's snapped inside the car, pull the trim off, find the cable, strip back the outer sleeve and pull the cable.
Don't break the grill.
Where all my moneys went.
Offline WadGTI
  • Golf GTI'er
« Reply #2 on: 20 May 2012, 17:06 »
thanks
Ave got to the outer cable hose the now and no sign of the cable inside. Ave cut a bit of the sleeProblem is...its a mteal oil and it aint easy to get itp open. It looks like cable travels through the wing.
Its goin to a pain to strip the dash lol.
Thanks
« Last Edit: 20 May 2012, 17:08 by WadGTI »
Offline WadGTI
  • Golf GTI'er
« Reply #3 on: 20 May 2012, 18:15 »
I have got to the cable however the wire is not inside it.
The cable has a black texture coating, inside of thatis metal coil and inside of a small white platic tube...bug no wire inside of that. Is there a chance the wire has went back up inside trhe cable?
