Golf mk3
hardmonkeys
How do you get the poxy fuel pump out?
Topic: How do you get the poxy fuel pump out? (Read 2036 times)
Bellend
20 May 2012, 16:23 »
Unscrewed (well chisled through the seucring ring) on the top of the pump, that's out but cannot get the bottom of the pump out.
How do they come out?
I'm probably more worried about blowing my face off as health and safety doesn't really exist in there at the moment.
Where all my moneys went.
topher
Administrator
Serious forum addict
fully functioning
Re: How do you get the poxy fuel pump out?
20 May 2012, 16:33 »
drop a match down the filler neck. pump will fly out.. along with a lot of other bits of car.
xAntiVenxm
GTI forum regular
20 May 2012, 17:28 »
Quote from: topher on 20 May 2012, 16:33
ROFL
Check mk3 maintenance dude, bound to be a guide in there
My Project..
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
20 May 2012, 17:58 »
Twist and pull, its kinda like a bayonet fitting, i don't think the MK3 has a spring, some you need to push and twist, im pretty sure you just turn it anti clockwise.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
gti gaz
20 May 2012, 22:26 »
took mine out the other day just push gently and twist simples
Any one in cornwall lets sort more meets!!!!
Len
10k hero
21 May 2012, 12:08 »
Mine was an absolute bugger to get out!
3 plastic lugs with rubber pieces locating in them, you need to get a finger in there and push back the rubber bits on all 3.
Then it lifts out.
Also watch the pipe connections as I busted one and had to buy a new pump!
Also I did a guide for this, so maybe if you had looked Josho!
www.sas.org.uk
www.the-ace.org.uk
Bellend
Reply #6 on:
21 May 2012, 12:23 »
OK cheers guys. Will try later. Need to get it shifted so I can cut the shell up. Probs just pull the tank out.
Len
10k hero
Reply #7 on:
21 May 2012, 20:32 »
Oh well now there is also a guide for that!
But its right pain also!
www.sas.org.uk
www.the-ace.org.uk
Golf mk3
hardmonkeys
