Author Topic: electric sunroof swap to manual???  (Read 1762 times)
Offline woodthorpe1717
« on: 19 May 2012, 20:29 »
right Ive got a completely weird sunroof issue, it opens slightly using buttons but not all the way and it will never shut itself properly unless you do it manually. i have replaced control button(twice), motor (twice) and still no look so was wondering if its possible to put a manual twisty arm thing ion so it actually works properly??
Offline itavaltalainen
Re: electric sunroof swap to manual???
« Reply #1 on: 19 May 2012, 23:05 »
Are the rails broken or seized up? Pretty common on mk3's
Offline Bellend
« Reply #2 on: 19 May 2012, 23:41 »
You'll need a new sunroof set up.
PM me if you want one, the runners will be siezing up and probably plastic bushes snapped. ;)
Where all my moneys went.
« Reply #3 on: 20 May 2012, 17:06 »
Is it definitely rails or bushes though as it opens manually perfect.....
