Author Topic: oily smell  (Read 3935 times)
Offline stainesy
oily smell
« on: 18 May 2012, 14:15 »
ok what i want to no is what could be the cause of a hot oil smell?
my car runs drives fine and there is no running issues at all and all is good.
but when driving the car. if i pull up in traffic engine runing waiting to go or if i stop sometime after driving a wile i get a smell of like hot or warm oil in the cab.
any ideas?
Offline murraymint
Re: oily smell
« Reply #1 on: 18 May 2012, 14:33 »
Rocker cover gasket lack?
josh
Offline stainesy
Re: oily smell
« Reply #2 on: 18 May 2012, 14:37 »
actuly you saying that there is a small leak on the right hand end of the block as you look at engine from the front coming from the rocker cover gasket.
is that what it is?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: oily smell
« Reply #3 on: 18 May 2012, 15:08 »
Split breather pipes is highly likely.
Offline Luke1981
Re: oily smell
« Reply #4 on: 18 May 2012, 15:17 »
It will be the rocker cover gasket, same thing happened to mine. They tend to perish around the semi circle area at each end. Not expensive to get a genuine VW one, 20 quid rings a bell.
If it's a split breather hose as Mr wronghorse suggests then they are more pricey. The air pipe breather hose from the rocker cover cost me nearly 50 quid from VW  :sad:
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline stainesy
Re: oily smell
« Reply #5 on: 18 May 2012, 15:21 »
yeah that is where mine is leaking from. on the right hand end as you look from the front.
i will change that first.
cheers peeps  :wink:
Offline itavaltalainen
Re: oily smell
« Reply #6 on: 18 May 2012, 19:47 »
Which engine do you have?
Got a good as new pipe lieing round from my 2.0, taken it off when I scrapped it cos I replaced it about a year ago before moving to the UK (VW Finland - almost 100€) Fits most 2.0 engines... Let me have you engine letters and I can confirm
Here's a link:
http://www.motor-talk.de/marktplatz/kurbelgehaeuseentlueftung-golf-3-passat-35i-2-0-aba-2e-t3876451.html
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: oily smell
« Reply #7 on: 18 May 2012, 19:50 »
The 1.8L / 2.0L engines are prone to leaking from the rocker cover gasket and the oil sits on the intake manifold as a puddle, then dribbles on the exhuast manifold and lets off a big puff of stinkey smoke!    The 2.0L just dribbles straight on the manifold and smells.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Re: oily smell
« Reply #8 on: 18 May 2012, 19:52 »
I know these leak, replaced both on my 2.0 2E and 1.8 AAM....
even done a how-to ;)
http://www.golfgtiforum.co.uk/index.php?topic=229781
Offline andy-gti84
  • lowanslow
Re: oily smell
« Reply #9 on: 18 May 2012, 20:35 »
mine done the same mate just change gasket an sorted it.  :smiley:
