Author Topic: Part number for stock DV?  (Read 1248 times)
Offline Nino
  • Insta - F6UGA
« on: 18 May 2012, 09:36 »
Just wondering if my DV is fooked while im waiting to get my 008 i might need to replace the nackard DV valve but when i rang VW they had no idea what i was talking about........
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline jamie1989
Re: Part number for stock DV?
« Reply #1 on: 18 May 2012, 10:26 »
MMm im not sure on the part number pal but if you call VW then I would imagine they would refer the DV as a recirculating valve instead. To be honest I would rather go to a scrappy if your replacing the crappy system.
Go and buy some 4mm silicone tube from anywhere and replace the crappy boost pipes from the inlet upto the DV and fbr. I would also check the pcv system and replace with a catch can which is very simple to do aswell. I know on the AUM engines the pipe from the rocker cover is prone to split so check this aswell.
« Last Edit: 18 May 2012, 22:25 by jamie1989 »
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline harlemex
« Reply #2 on: 18 May 2012, 17:44 »
I would have loved to hear how that conversation went.  :laugh:
Offline AD1.8T
« Reply #3 on: 18 May 2012, 19:52 »
Surely the standard recirc is going to cost 40+ so why not just buy the 008 direct from forge to save waiting/spending more !?
Offline cullygti
« Reply #4 on: 18 May 2012, 20:21 »
if you fancy a drive upto ebbw vale i got a standard one here you can have till you get your 008  :wink:
Offline Merlin1.8T
« Reply #5 on: 18 May 2012, 20:31 »
Try this (I got mine from an Audi dealership, should besame part though) 06A 145 710N Cost me £35 inc VAT
Offline cullygti
« Reply #6 on: 18 May 2012, 20:36 »
is there really any point spending £35 plus on one  :huh: when your gonna get a oo8 why not just get one outright instead of waiting till end of month if you need one that bad as you would still be saving money
