Author Topic: Fitted catch can but......  (Read 2374 times)
Offline jamie1989
Re: Fitted catch can but......
« Reply #10 on: 18 May 2012, 11:48 »
Thats intresting, thanks for the information.
I will have to find another for now then, but I can honestly say driving the car feels fine if not better now than before.
What problems could this cause you think?
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline rockmonkey69
« Reply #11 on: 18 May 2012, 12:04 »
The purpose of evacuating crankcase gases is more than just to maintain the breather tract clean, the reciprocating movement of the pistons on each revolution inevitably produces pressure, in short a build up of pressure behind the piston rings will increase the resistance to piston's movement and will not help the sealing of the piston rings.
You will only occasionally get pressure going to your catch tank from your tip and whether or not you can feel it is another thing but it's there and kind of defies the point of taking the preventative measure of fitting a well designed catch tank in the first place.
Offline jamie1989
« Reply #12 on: 18 May 2012, 12:14 »
Wow I wish I had this kind of knowledge lol
In that case I will find a hockey puck this weekend and fit it. simples  :smug:
