Author Topic: Mk2 1.8 Carb Question  (Read 2277 times)
Offline JC
  • Back in the North.
« on: 17 May 2012, 19:33 »
Right then, the old pierburg is playing up
waxstat has been reset as per RJs guide and advice from elsewhere.
still no good.
with other symptoms it could be a blockage in the inlet manifold water pipe
So, what DIRECTION should the water flow ?
theu the inlet mainfold and up to the carb ?
or thru the carb and back into inlet manifold.
as per the picture, i took the pipe off and had no flow in one direction, and a trickle in the other
thanks in advance
Offline clipperjay
Re: Mk2 1.8 Carb Question
« Reply #1 on: 17 May 2012, 19:45 »
I'm guessing Chuff top down it would have made sense to have gravity help circulation German tinking  :grin:
which direction does the other pipe next to go? If it goes down the one in question goes up vice versa if it goes up then one without pipe goes down.
Offline Santiago
« Reply #2 on: 18 May 2012, 08:00 »
Flow goes: head > inlet mani > autochoke housing > waxstat housing > metal water pipe.
Sounds like you need a new o-ring.
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 18 May 2012, 12:53 »
He's been told this repeatedly, by a VAG Tech.
I think he's fishing for someone to do the job, to be honest.  :kiss:
Offline JC
« Reply #4 on: 18 May 2012, 13:09 »
Actually mr hell I was confirming as per the vag techs instructions.
And even the man himself had to confirm direction ( or at least if it wasnt fcuked ) of flow
 :rolleyes:
Oh and he volunteered you to do it. Best take Friday 29th June off  :kiss:
Bits arrived this morning
Offline clipperjay
« Reply #5 on: 18 May 2012, 15:04 »
That engine still looks bloody clean, keep it nice ~Chuffy!
Offline JC
« Reply #6 on: 18 May 2012, 18:25 »
 :huh: engine is filthy, and has had a few bodges.
needs the alarm removing
and of course the inlet mainfold washer changing, THOMAS  :kiss:
  • Opinions я Us
« Reply #7 on: 18 May 2012, 19:54 »
Did the one on my Syncro a while back.  Snot that hard.
Offline clipperjay
« Reply #8 on: 18 May 2012, 20:41 »
What for that age?  :huh:
I'm sure Guy can wave his magic wand in there at some point  :smiley:
Offline bora55
« Reply #9 on: 18 May 2012, 21:17 »
now mate got a good twin choke webber that will bolt straight on for sale if your interested you can contact me on 07729830411 or email cbentley66@googlemail.com webber will give you more power and better fuel economy
