Author Topic: Brake set up question  (Read 1824 times)
Offline murraymint
« on: 17 May 2012, 19:26 »
Firstly, will mk3 16v brake callipers fit on g60 carriers? And would the carriers fit onto a 1.6 mk3.
I'm looking to up grade my brakes but wanting to stay 4 stud.
And also what 4 stud disc set up is best for the rear brakes?
Josh
josh
Offline Khare
  • The bear that khares
Re: Brake set up question
« Reply #1 on: 17 May 2012, 20:13 »
G60 is 280mm and 16v is 288mm. Not sure if calipers fit the carriers.
Offline murraymint
« Reply #2 on: 17 May 2012, 20:19 »
Would 8v mk3 callipers fit?
josh
Offline Khare
« Reply #3 on: 17 May 2012, 20:26 »
Pre 95 8v's had 280mm brakes so they should. However I'm not 100% sure if the 16v calipers or even the 8v ones may fit, so wait for someone to confirm.
Offline murraymint
« Reply #4 on: 17 May 2012, 20:46 »
Could I run 8v brake callipers and carriers but use g60 4 stud discs?
josh
Offline clipperjay
« Reply #5 on: 18 May 2012, 20:59 »
Josh the centre bolt holes are 9.5cm in between get a tap and start measuring for the carrier bolt holes on the hub! :wink:
Offline murraymint
« Reply #6 on: 18 May 2012, 21:06 »
cheers jay!. i will on monday when im back home.
josh
