Author Topic: Can I drive my 16v without power steering belt? Anticipating changing problems!  (Read 2944 times)
Offline b_boy02
Hello!
Going to try and change the power steering belt tomorrow but looking at it there seems to be lots of corrosion on the various nuts and bolts. If I manage to get it loosened off and cant get it tightened back up or some other problem occurs can I drive it without to my local garage. I don't think any other ancillaries are driven off that belt are they??
Offline mrsaunders
Your be fine but it will be very tough as its obviously isn't built the same as non assisted, in theory the faster you go the lighter it will get, but it would help if you were built like Rambo  :grin:
« Last Edit: 16 May 2012, 22:33 by mrsaunders »
Offline b_boy02
OK thanks! Can't bear the squealing on full lock any longer so I will have to be done!
Offline Len
Blowing the tyres up harder than normal will help a little
www.sas.org.uk
www.the-ace.org.uk
It will be fine just very heavy.
Offline leigh_harty
  • Audi AGU
Does the same belt not run the waterpump and alternator?
Dont lose your dinosaur!
Offline b_boy02
I don't think so on a 16v.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Nope, its a separate belt.
Offline Dogbot
Unless you have aircon.....
Aparently... i've never seen it in person tho....  :rolleyes:
Offline Len
Yea the belt does run air con on a 16v
www.sas.org.uk
www.the-ace.org.uk
