Author Topic: fitting new clutch cable  (Read 2236 times)
Offline mush
« on: 16 May 2012, 14:08 »
as above ive got a new clutch cabel as the old ones looking a bit bob,
I didnt want it snapping on me as going for a long drive at the weekend is there
a guide on here to fit it? looks straight forward.
ive got the europarts one cost me 22 bucks.
any help would be appreciated
MK2 golf 16v :-)
Offline dragonfly
Re: fitting new clutch cable
« Reply #1 on: 16 May 2012, 19:29 »
Manual or self adjusting?
Offline mush
« Reply #2 on: 16 May 2012, 19:55 »
its the self adjusting one
MK2 golf 16v :-)
Offline dragonfly
« Reply #3 on: 17 May 2012, 11:22 »
Fairly straightforward - if you compress the self adjusting spring you should get some slack in the cable.  Otherwise cut the old cable off.  Beware that if you do this the metal finger and rubber buffer will fall.  Assuming you have compressed the spring then on the release fork by the gearbox - remove the small metal finger under the rubber buffer.
Working inside the car - remove the drivers side low dash tray and then unhook the cable from the pedal.  Back in the engine bay - remove the plastic scuttle panel.  Then pull the cable through the bulkhead and off the release fork.
Refitting - keep the new selfadjusting spring compressed (it should already be).  Feed the cable through the fork, buffer and slide the metal finger back in. Pass the cable back through the bulkhead and attach the grommet.  Inside the car - hook the cable to the pedal.
There should now be some tension - remove the spring retainer and pump the pedal 10 -15 times.
Refit the lower dash tray, scuttle panel, clear up and take the car for a spin.
Most mk2 GTi owners go for the less troublesome manual adjust cable.
« Last Edit: 17 May 2012, 11:28 by dragonfly »
Offline mush
« Reply #4 on: 17 May 2012, 12:57 »
thanks dragonfly, i have a day off tomorrrow so will be fitting it then, going down to coventry on sunday.
MK2 golf 16v :-)
Offline dragonfly
« Reply #5 on: 17 May 2012, 13:07 »
No worries - just take you time, it's an easy job.
Offline mush
« Reply #6 on: 18 May 2012, 21:38 »
[q :cool:uote author=dragonfly link=topic=231417.msg2131075#msg2131075 date=1337256454]
[/quote]
Big thanks to dragonfly new clutch fitted today great guide
MK2 golf 16v :-)
Offline mush
« Reply #7 on: 19 May 2012, 10:34 »
it turns out i had ordered a manual one,
Ive fitted it fine as above however ive got a question about the lock nut on the cable
I've got the correct adjustment at the pedel, do i spin the lock the nut down on top of the plastic plunger or at the top of the cable if you know what i mean  :laugh:
the lock nuts on the plunger at the moment and not sure if thats correct can someone tell me. i dont want to crack the new plunger if it should be at the top of the cable.
MK2 golf 16v :-)
Offline dragonfly
« Reply #8 on: 19 May 2012, 19:33 »
For the manual cable - the gap between the base of the plunger and the bracket should be 10-12mm.  Turn the black base to the correct gap then lock the nut in place.
