Author Topic: Automatic Gearbox Probs!  (Read 1432 times)
Offline joshL
« on: 08 June 2005, 10:14 »
Hi all,
I've got a 1995 Golf with 31k on the clock. The problem that I am having is that, sometimes during driving the gearbox 'hunts' through the gears causing the car to jump all around the place, which is quite scary!
I had a diagnostics test done on the Auto ECU and it came back with an intermitent fault with the multifunction switch, which I have changed. Since then the problem is still there, and I have given up on driving the car because it is too dangerous to drive.
Does anyone have any ideas on what this could be or whether this is a common fault on the golf?
thanks
Josh
Offline AudiA8Quattro
Re: Automatic Gearbox Probs!
« Reply #1 on: 08 June 2005, 21:34 »
Faulty throttle potentiometer, or could be a faulty auto box ECU.
Offline joshL
« Reply #2 on: 09 June 2005, 00:18 »
I'm not too sure about the throttle potentiometer, if it was faulty wouldn't a fault code be logged on the engine ecu?
Offline adyh
« Reply #3 on: 09 June 2005, 09:30 »
It should show up on the Auto ECU . Where do you live  ? I can read fault codes , if you are around london .
« Last Edit: 09 June 2005, 09:32 by adyh »
