Author Topic: Any way of adjusting brake pedal? 1.6  (Read 1845 times)
Offline murraymint
« on: 15 May 2012, 21:09 »
In my 1.6 I have to push the brake pedal quite far down before the car starts braking. The discs and pads are good and when it does start to brake the brakes are pritty good. Just wondering if I can adjust them so that I don't have to push the pedal down as far?
Josh
josh
Offline m106_mk3
Re: Any way of adjusting brake pedal? 1.6
« Reply #1 on: 15 May 2012, 21:52 »
are they new disc and pads? or you mite have air in the system! both these will cause ur brakeing to feel poor
Offline itavaltalainen
« Reply #2 on: 15 May 2012, 21:55 »
Would suspect air in brake lines, faulty brake servo or even just a broken vacuum hose to brake servo
Offline murraymint
« Reply #3 on: 15 May 2012, 21:56 »
Na the pads were new at the start of the year and the discs are about year n half old.
josh
Offline murraymint
« Reply #4 on: 15 May 2012, 21:57 »
So first thing would be bleed the system and see if that helps
josh
Offline m106_mk3
« Reply #5 on: 15 May 2012, 22:23 »
dose it have drums on the back?
Offline murraymint
« Reply #6 on: 15 May 2012, 22:27 »
Yh
josh
Offline m106_mk3
« Reply #7 on: 15 May 2012, 22:39 »
the Brake Wheel Cylinder inside the drum mite be f*kd and lettin air in the system take the drums off and look for brake fulid you nite have to pull the rubbers back to see any but if you find some replace them.
Offline Screech16v
  • MK3 20vt AGU
« Reply #8 on: 15 May 2012, 22:47 »
Are your brake shoes adjusted correctly ,they need to be just off binding ,if theres to bigger space between the shoes and the drum then your shoes will have to travel a bit before they make contact with the drum thus giving you excess pedal movement before your brakes work  :smiley:
Offline murraymint
« Reply #9 on: 15 May 2012, 23:05 »
Okay cheers. Will check the drums first as bees less of a ball ache then bleeding  :smiley:
josh
