Author Topic: k03s part number and advice please  (Read 912 times)
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
« on: 15 May 2012, 20:26 »
Have found a k03s i think.part number is 06a 145 704s can someone confirm please?also can i run this mapped with a standard sidemount?thought stsndard sidemounts were good for 225ish :undecided:also would it be advisable to get a forge actuator.thanks
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: k03s part number and advice please
« Reply #1 on: 15 May 2012, 22:12 »
need the K03 number off the blue tag really, should be K03-052, 053 or 058 for the K03s
Yes you can run them with a standard side mount and Forge actuator is advisable if the current one is weak as they are a bit fiddly to change in situ
Offline symsymma
« Reply #2 on: 16 May 2012, 07:53 »
Yea he's saying k03-053 un silenced version.might get it then he reckons 75000 miles on it no cracks or play.then ill get actuator and map and get it fitted at rtech :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 16 May 2012, 21:38 »
off an AUM then :wink:
