Author Topic: Help needed Boost  (Read 800 times)
Offline 1stevester1
Help needed Boost
« on: 15 May 2012, 19:48 »
Right I fix one thing then the next thing goes today boost dropped to 5 psi flicked her off back on bang back up to normal then on the way home same again but won't come out of the limp mode carnt gets scan on it till sat so I looked first and I checked pipes but I'm unsure of what pipes I'm looking for if any one got any advice it would be appreciated could it be coil pack. clean the plugs still nothing
« Last Edit: 15 May 2012, 20:14 by 1stevester1 »
Offline 1stevester1
Re: Help needed Boost
« Reply #1 on: 17 May 2012, 19:46 »
Anyone?
Offline Chris.
« Reply #2 on: 17 May 2012, 22:05 »
What engine for a start?
Click For Build Thread
Offline Dalo Harkin
« Reply #3 on: 18 May 2012, 12:27 »
Have you changed anything recently? would be the obvious question
check around where the bottom engine cover is (under the plenum chamber) there is a maze of hoses that are prone to split
