Author Topic: 1 or 2 oil pressure switch AEE engion  (Read 1464 times)
Offline gizmomk3
  • on my way
« on: 15 May 2012, 19:36 »
 do I have 1 or 2 oil pressure swiches on my AEE engion was told that I have one by the oil filter but I can not seem to find it I can only find the one on the top of the block by the cam belt cover
« Last Edit: 15 May 2012, 20:14 by gizmomk3 »
Offline itavaltalainen
Offline gizmomk3
  • on my way
Re: 1 or 2 oil pressure switch AEE engion
« Reply #2 on: 15 May 2012, 21:12 »
So my AEE has 1 not 2 that's good thort I was going mad short of taking the engion out iv looked all over it
Have unplugged sender/ switch and have put it to ground will that stop the beeping it's driving me mad the beeping i just want to punch the dash till the beeping stops
« Reply #3 on: 15 May 2012, 21:52 »
Take the cable out that connects the speedo, connect pin 3 or 5 (both ground) to pin 8 (1.8 bar pressure switch).
From my quick experiment in my car this will stop beeping and warning light coming on when the engine is running (will warn with ignition on and engine off, as the procedure fakes oil pressure without engine running, but didn't beep with me this way!)
Let me know how this works out! Here a picture of the plug/socket - note cut-outs for orientation.
http://theresias.com/tutorials/1h_g4t/g3stecker.jpg
