Author Topic: dash lights  (Read 1169 times)
Offline Justins145bhpMK1
dash lights
« on: 08 June 2005, 09:27 »
Hhhmm first drive in the dark and I discover my 16v has no lights in the instrument binnacle. Are these easy to replace??????
Offline monzablue16v
Re: dash lights
« Reply #1 on: 08 June 2005, 09:34 »
short answer..... Not really!! you have to take out the dash and clocks hardest part is detaching mfa vacuum pipe and speedo cable, once it's out it's just a twist lock bulb to replace!, good luck.
Re: dash lights
« Reply #2 on: 08 June 2005, 09:39 »
Check the sticky post on the top of the MK2 forum ;)
http://www.golfgtiforum.co.uk/index.php?topic=10385.0
Re: dash lights
« Reply #3 on: 08 June 2005, 15:50 »
That was easy enough, only took 45 mins. Lets see what happens when it gets dark!!
Re: dash lights
« Reply #4 on: 08 June 2005, 15:57 »
You mean you put it all back together without testing it?  Asking for trouble there :grin:
Re: dash lights
« Reply #5 on: 08 June 2005, 16:55 »
IF it doesnt work then so be it. Ill use the mk3 when its dark!!
