Author Topic: Set of Golf Clubs?  (Read 3459 times)
Offline Dan n Nic
Re: Set of Golf Clubs?
« Reply #20 on: 16 May 2012, 20:15 »
Cheers all. Should i bother with graphite shafts or steel ok for a starting point?
Offline J_V_Dub
« Reply #21 on: 16 May 2012, 20:26 »
Don't bother with graphite for starters. If you get better at it then you can start investing in graphite but for the time being use steel and learn to control the ball with that.
Offline Martz
« Reply #22 on: 16 May 2012, 20:47 »
Makes no difference really at the start. What you need to get as a starting point are Regular shafts, these have more whip when you go through the ball. Once you have discover swing control and club head speed you will be able to adapt and move up to stiff shafts. If this makes no sense don't worry, it will eventually.
