Author Topic: Grown a pair of genitals?  (Read 2496 times)
Offline Harooshum
« on: 15 May 2012, 11:57 »
Hi everyone for 11 years ive been driving and tinkering with MK2's, recently I got myself a mk4 GTI turbo (AUM I think) with 29k!  First thing I was looking at was a forge dump valve, but before I bought one my car started making it's own DV noise!
Kind of sounds like a group-B rally car when changing gears but I didn't add anything and it wasn't doing it before.  I can't feel any power loss when on boost but I can't help but wonder if something has come loose and releasing pressure when it's not supposed to be.  Can anyone advise, thanks.
h.
Offline Toby
  • Car - less
Re: Grown a pair of genitals?
« Reply #1 on: 15 May 2012, 12:11 »
Possible boost leak id say.
Have a look under the inlet manffold, there's a breather pipe prone to splitting, start the car and get some
One to rev, and have a hand/ ear all over the pipe work!
Fingers crossed it something simple :)
Currently down under
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #2 on: 15 May 2012, 12:14 »
As above, probably a boost leak, also the DV's are pront to failing (the seal inside).  Smoke test would be a good option if you cant visually see anything
« Last Edit: 15 May 2012, 12:32 by bobbieboy69er »
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline harlemex
« Reply #3 on: 15 May 2012, 12:23 »
how do you do that then? park down wind to a bonfire?  :drool:
Offline monty9120
« Reply #4 on: 15 May 2012, 12:30 »
mine makes a slight sound when changing gear. is this normal?
  • MK4 1.8T AUM
« Reply #5 on: 15 May 2012, 12:32 »
it mapped? you have a uprated DV?
  • MK4 1.8T AUM
« Reply #6 on: 15 May 2012, 12:34 »
lol, light a fire and funnel the smoke into your pipes!
some people make their own, but for the sake of £30 your local garage should be able to accomodate :wink:
Offline Harooshum
« Reply #7 on: 15 May 2012, 12:54 »
TBH that sounds about right.  I do like this noise and when I fix it i will miss it  :cry:
I'll get a friend to help me later...
h.
Offline mcgee9t2
« Reply #8 on: 15 May 2012, 12:58 »
depends on how loud it is, even with just a panel filter you can sometimes hear it a little.
Offline Harooshum
« Reply #9 on: 15 May 2012, 13:16 »
No it's not that loud but I doubt anything regarding air filter because it just started happening all of a sudden.  Like I said i do like it, but looks like it has to go!
h.
