Author Topic: jonnybravo - trackday mk3  (Read 31186 times)
Offline jv
  • Administrator
« on: 14 May 2012, 12:28 »
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline jonnybravo
  • trackday weapon
Re: jonnybravo - trackday mk3
« Reply #1 on: 21 May 2012, 20:25 »
NOW FOR SALE
basically a mate and i decided one drunken night wed get a trackday car i found this car and within 7 days had a car and trailer sorted, we got our first day booked (abbingdon) and this is our story
ok so first came the car beleive it or not this was a CAT C !!!!! and itd been sat for 3 months and rather than the bloke scrap or break it made a perfect base car to start with
basically that was all the damage a wing and door, luckily no suspension damage and the car already has bigger 288mm grooved and drilled discs and front and rear eibach anti roll bars so it was a great base start
its got 160k but has a really strong engine and had been very well cared for so it seemed a shame to do this but weight counts so it had to been done, rather that than scraped or broken
so it started like this sun morning
and by sun lunch time looked like this
we then found the usual rust spots but they werent that bad but made the plates and welded in the patchs
and got the battered wing off
then we managed to get some old vw bora wheels and painted them to match the mood black look were going for
found a wing and door from a black vr6 (£40  :smug:)
also measured up and cut some bonnet vents
then off came the calipers refurbed them and bought so green stuff pads which will be fitted soon and then painted them red (my mates idea !!!)
and then came the serious weight reduction
got a bit crazy on the rear doors
BEFORE
AFTER
« Last Edit: 05 October 2013, 21:47 by jonnybravo »
Offline jonnybravo
  • trackday weapon
« Reply #2 on: 21 May 2012, 20:27 »
made some good progress today so here goes
got the wheels on but tommorow the coilees are going on so we may just run the 15"s and 5mm spacers but we'll see
then test fitted the strut brace we made, although will need to bend the plates a bit better and hopfully be painting it a funky colour
then fitted the front lip
then fitted some bonnet pins
Offline jonnybravo
  • trackday weapon
« Reply #3 on: 21 May 2012, 20:34 »
so saturday managed to get a fair bit more done this weekend
so off with the standard suspension
then on went the coilees, refurbed calipers, new green stuff pads, and braided break lines and DOT 4 brake fluid
then after lagging the manifold the mani, decat and rear sections were fitted
« Last Edit: 26 May 2012, 23:30 by jonnybravo »
Offline jonnybravo
  • trackday weapon
« Reply #4 on: 29 May 2012, 22:50 »
progress update, we finally got the strut brace painted
fitted a new cambelt
also sourced some vr6 wheels
then removed the blank light covers and fog lights and made some gauze covers
then cable tied in some duct piping to aid break cooling
then adjusted the rear coilovers and giving it its final ride height and its now starting to look a bit more track ready albeit its very dirty !!!
« Last Edit: 29 May 2012, 23:15 by jonnybravo »
Offline jonnybravo
  • trackday weapon
« Reply #5 on: 02 June 2012, 21:33 »
as our first track day is getting closer were getting really close to being ready so heres a bit more progress
decided to do some recycling using an old airfilter
made some kick plates
then got the freshly painted vr6 wheels and 10mm spacers fitted
the wheel weights are pretty tight tho !! :smiley:
then adjusted the front camber
so this is where we now stand with it so far
Offline jonnybravo
  • trackday weapon
« Reply #6 on: 10 June 2012, 10:59 »
ok so we finally got all the last few jobs done on the car, and its all ready for friday so we've actually done it
although its still a work in progress and eventually we're going to fit bucket seats, roll cage, harnesses, a nice steering wheel and gearknob but for now hes at a level where we can happily use him on the track.
« Last Edit: 05 October 2013, 21:35 by jonnybravo »
Offline jonnybravo
  • trackday weapon
« Reply #7 on: 19 June 2012, 23:37 »
well the 15th came and the car was ready for its first outting so got him loaded up and off we went
and what a day, the car felt really well setup and i was suprised at just how well the car went and with a virtually faultless day we drove it hard all day and actually kept up (and over took ) with alot more capable cars
some action shoots
« Last Edit: 13 August 2012, 18:20 by jonnybravo »
Offline jonnybravo
  • trackday weapon
« Reply #8 on: 13 August 2012, 18:41 »
ok so weve got another trackday booked for the sept 14th and decided to do a few bits to the golf
we then found one of the engine mounts was knackered so decided to change the front and drivers side mounts and give the car a oil change
new mounts
mounts fitted
also painted the rear tow eye
and then decided to strip the interior and paint all the inside satin black
and also purchased some mint subaru sti seats which we fitted
« Last Edit: 13 August 2012, 18:43 by jonnybravo »
Offline ALTERNATOR
« Reply #9 on: 02 September 2012, 11:39 »
Nice work so far :smiley:
I've got one question. Looks like you removed the rear window regulator and all that stuff. What did you use to keep the windows up. Thinking of doing the same to mine, regulators are shot anyway :grin:
