Author Topic: 16v dials in a 8v car  (Read 3631 times)
Offline Dizzie
  • Make friends with your fast
« on: 01 October 2003, 13:50 »
are they gonna work exactly the same or gonna be out. ie, when the car is at 3000rpm the dials are reading 3500rpm or something like that.
anyone know?
cheers
Offline Gambit
Re:16v dials in a 8v car
« Reply #1 on: 01 October 2003, 15:23 »
you'll need to change the final drive on the gearbox end of the speedo cable
16v (160mph) clocks use the red drive
8v (140mph) use the white drive
dunno bout the rev counter, i assume it should work fine
Offline tinman
« Reply #2 on: 01 October 2003, 16:36 »
Rev counter has a different scale.
Regarsd,
Tin
Offline Dizzie
« Reply #3 on: 01 October 2003, 23:47 »
so what do I have to do to make them read right?
Offline tinman
« Reply #4 on: 02 October 2003, 18:36 »
after long and careful deliberation - i have an answer.
A squint.  8)
Regards,
Tin
Offline modulater
« Reply #5 on: 03 October 2003, 12:57 »
Why do you want to put them in your car anyway? are you changing the engine and gearbox?
Offline Dizzie
« Reply #6 on: 03 October 2003, 14:57 »
trying to gather funds for a 20v T and was told I'd need some 16v dials cos I'd be off the clock with the 8v ones.
Offline tinman
« Reply #7 on: 03 October 2003, 18:34 »
I have someone sitting on my shoulder who is saying that it should not matter too much as the rev counter is displaying a pulse from the ignition, rather than a completely mechanical set up like the speedo.
Regards,
Tin
Offline Dizzie
« Reply #8 on: 03 October 2003, 21:17 »
ah ok. so the revs will sort themselves out while the speed would need setting up from the gearbox. I get it now :)
cheers
