Author Topic: Slight noise when turning a corner at low speed  (Read 957 times)
Offline Mk2_tel
almost sounds like powersteering pump? like a vibartion noise only at low speeds
Offline Toby
  • Car - less
Re: Slight noise when turning a corner at low speed
« Reply #1 on: 14 May 2012, 11:26 »
Anything rubbing on arb if your low?
Currently down under
Offline mcgee9t2
« Reply #2 on: 14 May 2012, 13:05 »
my initial thought.
however it could be ps pump. have a look at the fluid levels in it. also if your stationary and turn full lock do you get a screetching, normally if pumps on its way out you get a bit of a screetch iirc
