Author Topic: Mayo gunk  (Read 1369 times)
Offline gizmomk3
  • on my way
Mayo gunk
« on: 13 May 2012, 21:17 »
Just found mayo like gunk in the breather pipe that comes from the bottom of the engion in to the air box this ant normal right ??
Iv got an AEE engion if that helps
Offline itavaltalainen
Re: Mayo gunk
« Reply #1 on: 13 May 2012, 23:10 »
Driving short trips a lot? Had that in my breather pipe even after motorway tours, it's just oil/water mixture, just clean it out with brake cleaner but it'll be back pretty soon through most of the year, maybe not high summer.
As long as you don't have excessive mayo in coolant expansion reservoir or cylinder head all is ok (you'll probably have some on the oil filler cap or even cam shaft plastic cover but that's fairly normal - in particular when you're running mostly short trips.
Offline gizmomk3
  • on my way
Re: Mayo gunk
« Reply #2 on: 13 May 2012, 23:14 »
I wouldn't say I do short trips the car gets used for work I do 36 mile a day 18each way that's not that shirt of a trip is it ???
Offline search
Re: Mayo gunk
« Reply #3 on: 13 May 2012, 23:21 »
check your oil level could be to high.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline gizmomk3
  • on my way
Re: Mayo gunk
« Reply #4 on: 13 May 2012, 23:37 »
Seems normal when I checked it I only use the car for work and work only the wife hates her so we go every where in the Astra pluses it's the wife's fule not mine lol might start using my little mk3 more really fun to drive and easy to work on With a bit of help from lads on here lol
VW BUSH
Re: Mayo gunk
« Reply #5 on: 14 May 2012, 20:35 »
Quite normal
