Author Topic: 1991 16v Knocking sound after gear change.  (Read 1162 times)
Offline roar
« on: 13 May 2012, 18:59 »
Noticed a knocking sound when pulling away and especially changing into second and low speed. It happens when i put my foot on the power after changing gear. It knocks once or twice then pulls away fine.
Engine mounts? Any ideas?
Offline clipperjay
Re: 1991 16v Knocking sound after gear change.
« Reply #1 on: 13 May 2012, 19:09 »
Sounds like a engine mount get a crow bar see if get play on some of the running gear!
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #2 on: 13 May 2012, 19:43 »
Yep, most likely to be the front engine mount, easy to spot, by grabbing hold of something solid on top of the engine, and rocking it back and forth, while looking down near the bottom of the radiator at the front engine mount... all should become clear
Thom
Offline fraser
« Reply #3 on: 22 May 2012, 11:42 »
Had this on mine, turned out to be the exhaust mount, the one thats shaped like an 8 the middle bit went so it kept clonking the body.
