Author Topic: bad idle when the fuel tank is half or less  (Read 1411 times)
Offline torontovka
« on: 13 May 2012, 07:09 »
Hi guys,
I noticed when my fuel tank is half or less the car idle very rough and bad and the RPM keeps going up and down.. this issue goes when the tank is more than half or full..
one more issue the fuel guage when the tank is full it shows only half..
what Do i have to check
regards
E34 540i 6 Manual
Eibakh Pro Kit | Blistein Shocks | EAT Chip | Racing Dynamics Front Stressbar | Racing Dynamics Swaybar Kit | 850cis Front Brake Kit | Zimmerman Cross-Drilled Brake Rotors All Arround | Hawk Street And Racing Brake Pads |Angel Eyes | 8000k HID Xenon Kit All Arround | Plasma Coils | JB Racing Lightweight Aluminum Flywheel
Vw MK2 Golf 16v
Offline tylang10
Re: bad idle when the fuel tank is half or less
« Reply #1 on: 13 May 2012, 12:23 »
Hi,
Had a similar problem with my MkII GTi found it was the tank fuel pump, this is in the boot, right hand side held in by a circular plate. What I can remember cost about £25 from GSF. fairly easy to fit, be aware of the fuel fume when you do it!! As far as the fuel gauge. sticky float arm or possible wire broken on the wiper coil?
Cheers Terry
Should have said it's called a 'tank lift pump'
« Last Edit: 13 May 2012, 12:26 by tylang10 »
Offline roar
« Reply #2 on: 13 May 2012, 18:57 »
This could also be the uptake pipe out of the tank. I had an issue on a mark 1 golf where the pipe got clogged and unless the tank was nearly full it would stall the engine through lack of fuel.
