General discussion
Old Mountney steering boss..... Help!
Topic: Old Mountney steering boss..... Help! (Read 1708 times)
timmy7hands
13 May 2012, 03:52 »
Right,
I've just aquired a lovely old Mountney steering wheel that i've been bugging a mate about for a very long time now. Only problem is i have a '97 mk3 golf 16v and i cant seem to find a boss kit anywhere that will fit both the mk3 spline, and the wider spaced stud pattern of the older wheel.
Any suggestions or advice would be greatly appreciated!
timmy7hands
Re: Old Mountney steering boss..... Help!
14 May 2012, 09:31 »
Anyone?!................any ideas?
1stevester1
GTI forum regular
14 May 2012, 18:41 »
You could try an engineering shop to fabricate one up
spikenipple
14 May 2012, 21:17 »
If you can source a boss with the MK3 spline and measure (accurately) the stud pattern and PCD of the wheel, I can machine the boss to fit the wheel for you. Might take me a couple of days as I only have limited time on the machines at work.
DOA
14 May 2012, 22:01 »
Can you find one to fit the earlier, smaller Mk2 spline pattern? If so, you can remove the spline from a Mk3 steering column to reveal the smaller spline underneath though I seem to remember a couple of issues arising from that that have been covered on here before. Its what I ended up doing on my big spline Mk2 column and there are a fair few threads on here describing the removal procedure (prepare to get brutal!
timmy7hands
17 May 2012, 00:25 »
Thanks for all the help guys! a friend of mine has actually found an old suzuki one he reckons will fit ( ?!
If not though i'll definately pm you about that offer of yours spikenipple! how much would you want for the job?
spikenipple
Reply #6 on:
17 May 2012, 09:44 »
Whatever it costs to post the parts back to you bud
If it comes to it, it would probably be best to send me the wheel if you can't get a pcd within 0.25mm or so, I wouldn't want to get it wrong and ruin the boss!
General discussion
