Author Topic: hesitation when cold  (Read 1526 times)
Offline monty9120
« on: 12 May 2012, 20:48 »
hi all. my 1999 golf 1.8 turbo can be a bit hesitant when cold. sometimes i have to put my foot down and it wont go anywhere fast. it never seems to do it when warm.
sometimes when i kick down it feels faster some days then others
im going to give it a service over the weekend, just wondered if this is a common problem, i dont seem to have any air leaks i can see or hear
Offline richw911
Re: hesitation when cold
« Reply #1 on: 12 May 2012, 20:53 »
Any fault codes?
Offline monty9120
« Reply #2 on: 12 May 2012, 21:19 »
nope nothing. im hoping some new plugs will sort it. shall i grease the connectors on the coil packs?
Offline richw911
« Reply #3 on: 12 May 2012, 21:32 »
Does the temp gauge sit at 90 once it has warmed up? No need for grease?  :undecided:
Offline james2
  • No scammers please.
« Reply #4 on: 12 May 2012, 22:12 »
let it warm up before putting your foot down.  :tongue: Look after it / give it a good service.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline BarryMKIV
« Reply #5 on: 12 May 2012, 23:40 »
Try cleaning your throttle body. It's practically free, easy to do, and it solved my hesitation problems.
25th Anniversary GTI 1.8T No. 0441
Offline monty9120
« Reply #6 on: 13 May 2012, 11:36 »
tempreture always sits at 90 when warmed up.
sometimes i need to get moving and it just jerks. its weird as sometimes it does it more then others
Offline richw911
« Reply #7 on: 13 May 2012, 11:38 »
Offline monty9120
« Reply #8 on: 14 May 2012, 18:15 »
just serviced my car. theres oil leaking into the first second and third cylinder.
i have ordered a rocker cover gasket set. so will see how it goes.
a busted sump nut. seized fuel filter. a day in the life of a vw  :laugh:
