Author Topic: Clutch noise??  (Read 2897 times)
Offline sundaydriver
Clutch noise??
« on: 12 May 2012, 19:38 »
ohhh noooo, think i have a problem straight away. :sick:
With the engine running and without the car in gear, when i press the clutch and release it i get a loud clicking type noise? Only happens when the engine is running and is more noticable when driving.
Could anyone be so kind and try theirs to see if it clicks on release, didn't notice it on the GTI.
« Last Edit: 12 May 2012, 20:21 by sundaydriver »
2012 Golf R, APR STAGE 2+, BCS power valve TB exhaust, loba HPFP, evoms intake, Rising blue, 19" Talladegas -BMW M2
Offline Snoopy
  • Moderator
  • Geoff.
Re: Clutch noise??
« Reply #1 on: 12 May 2012, 20:50 »
My gti has always done similar.
A guess but on yours May also be the heldex drive shaft engaging
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Re: Clutch noise??
« Reply #2 on: 12 May 2012, 20:54 »
Thanks Snoopy.  :smiley:
Offline Steve30
  • Ed30 .
Re: Clutch noise??
« Reply #3 on: 13 May 2012, 10:14 »
The joy's of DSG I dont miss the clutch  :wink:
Tiguan quicker than the Golf
Offline I.D.C.
Re: Clutch noise??
« Reply #4 on: 13 May 2012, 11:43 »
Simlour problem. Dealer fitted new clutch problem solved :)
Offline Snoopy
  • Moderator
  • Geoff.
Re: Clutch noise??
« Reply #5 on: 13 May 2012, 11:47 »
 :tongue:
cheaper to fix and less like to strand you at the side of the road with a flashing dashboard as it gets to engage two gears at the same time when your mecatronic unit has a hissy fit  like it did to us.
Mk6 GTI  &  Mk1 GTI
Re: Clutch noise??
« Reply #6 on: 13 May 2012, 11:53 »
Going to give it a few more miles and if it persist's will get it booked into the dealer's.
« Last Edit: 21 June 2012, 19:40 by sundaydriver »
Offline Snoopy
  • Moderator
  • Geoff.
Re: Clutch noise??
« Reply #7 on: 13 May 2012, 11:58 »
Try a search on YouTube I remember seeing similar before. Sadly the fumes from the wax I just put on the car are overpowering and not leering me think :embarassed:
Mk6 GTI  &  Mk1 GTI
Offline Snoopy
  • Moderator
  • Geoff.
Re: Clutch noise??
« Reply #8 on: 16 May 2012, 21:11 »
Did you get this looked at?
Another thought also check your is working as a 4wd there has been quite a few failures of the new generation haldex as fitted to the mk6 r
Mk6 GTI  &  Mk1 GTI
Offline VWFool
Re: Clutch noise??
« Reply #9 on: 19 May 2012, 19:09 »
It maybe the flywheel, i'm not sure if they are still using the dual mass but if they have fitted a faulty one at factory.... If it's still under warranty go to your local VW dealer?
