Author Topic: Wobbly speedo needle  (Read 4272 times)
Offline j_s
« on: 07 June 2005, 15:49 »
Hi guys
I've got a wobbly speedo needle when accelerating or in but idle less so. It's ok when maintaining a speed though.
What do I need to do to fix this?
It's an 88 8v.
Thanks guys :)
James
Offline Justins145bhpMK1
Re: Wobbly speedo needle
« Reply #1 on: 07 June 2005, 16:41 »
COULD BE A SIGN THAT YOUR GEARBOX IS WORN. PROBABLY THE SPEEDO DRIVE THOUGH,! :laugh:
Offline KKK
« Reply #2 on: 07 June 2005, 19:01 »
Change the speedo cable.
KKK
Offline Alexg40
« Reply #3 on: 07 June 2005, 22:40 »
That's exactly what mine was doing just before the speedo stopped altogether. :tongue:
Offline j_s
« Reply #4 on: 07 June 2005, 23:25 »
And what did you do to fix it? :D
I had this on one of my old old Mk1 Fiestas but it kept working, I was 17 then and didn't give a damn but now I want it all working as it should :)
James
Offline hockeylad72
« Reply #5 on: 08 June 2005, 08:56 »
had same problem, changed speedo cable and drive in the gearbox works as it should now
would advise getting genuine VAG speedo cable as I originally was going to get one from Euro Car Parts, the grommets on the ECP as solid plastic and it's practically impossible to fit the grommets
cheers
Davie
Offline j_s
« Reply #6 on: 08 June 2005, 12:26 »
Thanks guys, what am I looking at with changing the cable, dash off etc?
Hockeylad, you said you changed the speedo cable but what do you mean by drive in the gearbox?
James
« Reply #7 on: 08 June 2005, 13:50 »
I rerouted my cable to under the rain tray which helped, then I cut off the damaged sections of outer sheathing and cleaned out bits of it that were trapped in the gaps.  Then I sprayed WD40 down the hgaps, dried off the excess and taped over the holes in the sheathing with Duck tape.  After a day or so of driving the WD40 worked its way thru the cable and the problem was completely solved, cheaper than a new cable thats for sure :)
Offline Alexg40
« Reply #8 on: 08 June 2005, 15:44 »
Genuine cables are beginning to become obselete now too. My one was the last one for my cars chassis code.
Offline hockeylad72
« Reply #9 on: 08 June 2005, 21:55 »
j_s
the drive in the gearbox fits to the end of the speedo cable
http://volkswagen.msk.ru/vw_doc/eva2/BD01/ch4.1.1.html
link may be of some help
cheers
