Author Topic: rear arch to sidewall diference help!!  (Read 1565 times)
Offline jettagreeny
« on: 12 May 2012, 15:17 »
Hi just put some ronal turbs on my mk2 jetta gt and the driver side had a nice gap between the sidewall and the lip of the arch. When i fitted the passanger side the sidewall was touching the lip, i imetiatly thaght bent chassis but i put new tires on it a year ago and there is no unever wair!
Anyone have this problem or any advice help please.
Cheers oli
Offline dom
  • Back in a Mk4
Re: rear arch to sidewall diference help!!
« Reply #1 on: 13 May 2012, 11:36 »
The mk4 is renowned for having a wider track on the passenger side than the drivers side. I've heard that the axle can be manhandled over a little to balance out the difference, but I'm not 100% sure if it will work on a Mk2 as well
« Last Edit: 14 May 2012, 17:44 by dom069 »
« Reply #2 on: 14 May 2012, 00:02 »
Mk2's always tend to have a difference, I believe you can shim the rear beam to sort it.
