Author Topic: Coolent Leak  (Read 1543 times)
Offline Thrash_cj
Coolent Leak
« on: 12 May 2012, 13:51 »
The past few days my golf has been going thru coolent like no tomorrow.
After 10mins of looking today I have found the issue  :smiley
Does anyone have the part number for the lovely rusty item in the picture so I can resolve the issue
http://s1220.photobucket.com/albums/dd460/Thrash_cj/?action=view&current=rusty.jpg
Thanks
Thrash
Edit: should have said, its an ABF and the location if the item in the pic is just under the inlet mani
« Last Edit: 12 May 2012, 13:53 by Thrash_cj »
Had
VW Golf mk2 Driver
VW Golf mk3 16v GTI
Have
VW Golf mk4 GTTDI
Offline itavaltalainen
Re: Coolent Leak
« Reply #1 on: 13 May 2012, 15:16 »
That's the main water flange, it's is the one at the front isn't it?
part number is 037121132J flange with gasket, I would also advise to get the three bolts (M6x22 p/n N 90280901), with all that leaking going on they might be well rusty. If you don't want to buy from VW then just go and get flanged hex head M6x20 bolts like these: http://www.ebay.co.uk/itm/M6-x-20-GOLD-ZINC-HEX-FLANGE-8-8-HEAD-BOLTS-X-10-pcs-/180711761400?pt=UK_DIY_Material_Nails_Fixing_MJ&hash=item2a1342a5f8.
Don't make the mistake of buying stainless ones though, they might not rust but your engine will.
Offline Thrash_cj
Re: Coolent Leak
« Reply #2 on: 13 May 2012, 21:45 »
Cheers itavaltalainen
Yeah its the one at the front.
I tried explaining to ECP but it was no good hah
Also thanks for the links too
Had
VW Golf mk2 Driver
VW Golf mk3 16v GTI
Have
VW Golf mk4 GTTDI
Re: Coolent Leak
« Reply #3 on: 13 May 2012, 22:26 »
np, just found the part online, even better VW genuine one for 12£ : http://www.shop4volkswagen.co.uk/product/Seal_037121132J
in addition you'll also need the gasket 027121139A (~3£ from same site), forgot about that (my 8v's only have an o-ring).
Offline Gash
Re: Coolent Leak
« Reply #4 on: 29 May 2012, 00:14 »
mine has started to leak too!
rang vw up and described it down the phone and they ordered it for me! :D
