Author Topic: NSR will not lower  (Read 1293 times)
Offline lukeyyyyyyy21
NSR will not lower
« on: 11 May 2012, 22:03 »
Lowered my mk4 gti 1.8t on eibachs sportline springs. 50 front, 35 rear. this didn't drop rear much so got fk 60mm springs for the back. it's lowered OSR a bit more but the NSR is still really high and hasn't lowered at all.
I have checked and taken the damper out and it is not seized and in full working order.
The coil spring is located correctly in the top rubber mount and there is no debris in the bottom of the lower arm cup where it locates.
The coil spring is the right way up.
I have swopped coil spring and damper from side to the other and fault is still present.
I loosened the rear beam bush bolts on either side and pulled the car up and down to see whether when the bushes were done this affected it by doing 1 side at a time so it is all leveled out.
Anyone got an idea?
the master tech at work is stumped.
fellow golf lovers, anyone had any issues with one side not lowering?
« Last Edit: 11 May 2012, 22:07 by lukeyyyyyyy21 »
Re: NSR will not lower
« Reply #1 on: 11 May 2012, 23:50 »
Not a chance you have the old top mount stuck in the top housing.
« Reply #2 on: 12 May 2012, 14:59 »
 it came off with the old spring. put it onto the new spring, fed it up in
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 12 May 2012, 16:32 »
pics?
Offline JimBR
« Reply #4 on: 12 May 2012, 16:46 »
Not the way the car's parked or anything is it?
« Reply #5 on: 12 May 2012, 21:06 »
no this is on all levels always higher on left rear.
Offline Toby
  • Car - less
« Reply #6 on: 12 May 2012, 21:17 »
Currently down under
Offline stevelfc
« Reply #7 on: 12 May 2012, 21:29 »
axle twisted ? or had rear damage ?
« Reply #8 on: 13 May 2012, 02:33 »
it's had slight damage at the front, had a cat d, previous owner. but panels match up at front good enough when played around. no accident at the back to my knowledge.
