Author Topic: New wheels fitted! bought from jnufcuk  (Read 2721 times)
Offline mcgee9t2
Re: New wheels fitted! bought from jnufcuk
« Reply #10 on: 11 May 2012, 17:49 »
looks crap! u need 17" wheels... much better  :undecided:
You're joking! You'd have no tyre wall left, you'd slide off the road trying to keep up with me. At least some tyre wall lets the tyre give a little. You don't want to lose performance just because you think it looks good by looking as though it doesn't have any tyres.
i have 17" wheels and they have quite alot of tyre wall left, getting towards two inch
also these wheels are 18"
« Last Edit: 11 May 2012, 17:54 by mcgee9t2 »
Offline Dalo Harkin
« Reply #11 on: 11 May 2012, 18:23 »
18's on mine too - look  :cool: just need to be refurbed lol
Offline Ant1981
  • Feed me, prod me
« Reply #12 on: 11 May 2012, 18:53 »
Your speedo must be reading wrong as the standard tyre is just under two and a quarter inch with 16 inch wheels.
'09 Kawasaki Ninja ZX-6R
Offline mcgee9t2
« Reply #13 on: 11 May 2012, 19:03 »
nope it reads exactly the same and its the same OD as my standard alloys. 225/45/17 and if you do 45% of 225 you get 101.25mm therefore roughly 100mm for the whole side wall and once you take into context the bead that goes inside the alloy and the curved part of the tyre your looking at around 5 cm. i shall go get a pic to prove
« Last Edit: 11 May 2012, 19:05 by mcgee9t2 »
Offline Ant1981
  • Feed me, prod me
« Reply #14 on: 11 May 2012, 19:05 »
nope it reads exactly the same and its the same OD as my standard alloys. 225/45/17 and if you do 45% of 225 you get 101.25mm therefore roughly 50mm from rim to tread... shal get a pic in a mo to show
I'll assume it's not a MK4 from this point onwards shall I then?
Offline mcgee9t2
« Reply #15 on: 11 May 2012, 19:13 »
yep it is a mk4 and there the same size as the OD on the standard wheels
« Last Edit: 11 May 2012, 19:17 by mcgee9t2 »
Offline cullygti
« Reply #16 on: 11 May 2012, 19:17 »
how could the speedo be wrong the circumfrence of the wheel is the same from 16" with correct tyre size to 18" with 225 40 18 its when you go bigger than that size that throws the speedo out
Offline Ant1981
  • Feed me, prod me
« Reply #17 on: 11 May 2012, 19:19 »
Are your other wheels standard? I thought they were all 16" 55mm profile as standard.
Offline mcgee9t2
« Reply #18 on: 11 May 2012, 19:22 »
yep standard and nope my other wheels are 15" avasus alloys.
Offline Ant1981
  • Feed me, prod me
« Reply #19 on: 11 May 2012, 19:22 »
It's the bit (a little towards the top) where he said his wheels are 18", not the OD is 18" of the tyre and the wheel, I assume now that then, he meant OD.
