Author Topic: Coolant hoses  (Read 1186 times)
Offline AntMk3GTi
Coolant hoses
« on: 11 May 2012, 10:58 »
Hi
Does anybody know the internal diameter of the smaller coolant hoses on top of the engine bay near the expansion tank, the ones that lead to and from the expansion tank and towards the back of the engine bay?
Thanks
Offline AntMk3GTi
Re: Coolant hoses
« Reply #1 on: 11 May 2012, 11:02 »
...engine is 1.8t AUM.
Offline jamie1989
Re: Coolant hoses
« Reply #2 on: 11 May 2012, 11:13 »
9mm rings a bell mate.
Pull one off and measure  :wink:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline AntMk3GTi
Re: Coolant hoses
« Reply #3 on: 11 May 2012, 11:35 »
Ok cheers. I was looking at lengths of silicone in either 3mm, 4mm or 5mm and was going to order 4mm. But if you say 9mm yeh I think i'll double check and measure one.
I thought 4mm cos they look about the same size as the vac hose on the diverter valve.
Offline cullygti
Re: Coolant hoses
« Reply #4 on: 11 May 2012, 11:51 »
i measured them at 8-9mm
Offline AntMk3GTi
Re: Coolant hoses
« Reply #5 on: 11 May 2012, 12:06 »
Cheers, and this is definitely the internal diameter not outer?
Offline rio_gti
Re: Coolant hoses
« Reply #6 on: 11 May 2012, 13:15 »
i just pulled one off then measured it, it was 8.5" then it started going floppy  :smug:
Offline jamie1989
Re: Coolant hoses
« Reply #7 on: 11 May 2012, 13:46 »
Damnnnn I have a good guess   :laugh:
Offline thatwillis
Re: Coolant hoses
« Reply #8 on: 11 May 2012, 13:51 »
*shakes head*  :grin:
Offline jamie1989
Re: Coolant hoses
« Reply #9 on: 11 May 2012, 15:38 »
 :grin: I should have seen this coming hahaa
