Author Topic: BMW645 enhancement detail  (Read 4592 times)
Offline butler2.8i
« on: 11 May 2012, 09:39 »
An enhancement detail on a BMW645 which due to the amount of swirls was being robbed of any depth to the pant or reflections. Which stands out even more under the halogen spot light when doing the 50/50 shots
And the dirt build up and zebra stripes on the roof was also letting the car down
Products and equipment used
Uber microfiber towels
Chemical guy’s woolly mammoth drying towel
3m yellow pads 150mm 75 mm
3m blue pads 150mm 75mm
140 mm Lake county ultimate last stage Pad
Halogen site lights
Makita rotary polisher
DA Polisher
Scholl s17+
Scholl S40
Carpro eraser
303 convertible top cleaner
303 high tech fabric guard
Blackfire all finish paint protection
Blackfire Midnight sun wax
3m masking tape
Meguiars APC
Costco microfibre towels
Meguiars hyper dressing
Valet pro citrus bling
Bilt Hamber AutoWheels
Valet Pro PH neutral Snowfoam
Valet pro tyre dressing
AMDetails AMbubbles
Bilt Hamber clay bar
Autosmart Tardis
Various brushes
Kranzle pressure washer
Carpro Sheepskin wash mitt
Carpro Dlux
Noodle wash mitt
Carpro Lambs wool wash mitt
Poorboys microfibre clothes
Uber buffing clothes
Autobrite Snow foam gun
Chemical guys Jetseal 109
Autobrite Repel
Autosol metal polish
00 grade wire wool
Some photos of the car before I start
The roof
The car was then given its first coat of snow foam whilst this was dwelling I went round the car using APC in a foaming head bottle cleaning the fuel filler area and various gaps and grills. The snowfoam was then blasted off with the pressure washer, and then the car was given another coat of the same mix snowfoam and then cleaned off again at this point it started to rain so the car was brought into the unit.
The car was washed using the 2 bucket method with grit guards in both buckets and a Carpro lambswool wash mitt.
The car was then rinsed off using an open ended hose and I then went round the car with Tardis which was left to go to work before being wiped down with microfibre clothes. The car was then given a coat of Ironx again left to do its stuff before the car was washed doing using the pressure washer.
The car was clayed using citrus bling and water mix (10 to 1) and a Bilt hamber soft clay bar which helped to pull more contaminates from the paint work it was then rewashed using the same method and dried using the woolly mammoth. As it was still raining the wheels where left until I could get the car back outside but they where cleaned using  Bilt Hamber AutoWheels which is another new product to me which I’m really impressed with as fronts of the wheels was just given a coat of this and then left to dwell for a couple of minutes then removed using the pressure washer, the inner face’s of the wheels are in a very poor state I think the owner is looking at getting them powdercoated in the original silver finish as the really let the final look of the car down this is something we will be able to offer as part of our detailing packages soon.
The arches where next and they where sprayed with APC and cleaned using various brushes and a noodle wash mitt. They where then sprayed with Tardis which was left do its stuff whilst I moved onto the next arch before going back and being wiped down with a microfibre cloth.
The roof was cleaned using the 303 cleaner which I did twice as the amount of muck and mold on the roof was unreal
Before I started polishing the car I decided to go round and dress the arches using Meguiars hyper dressing
A few 50/50 shots using my site lights
Offline butler2.8i
Re: BMW645 enhancement detail
« Reply #1 on: 11 May 2012, 09:40 »
I then taped the car up and went round with various yellow 3m pads and Scholl s17+ polish, each panel was given a wipe down with carpro eraser after polishing to check finish and remove any polishing oils.
After this I went back round the car with the Scholl s40 and a the 3m pads to give the finish a little more depth
The Roof of the car was given its first coat 303 fabric guard which was left to dry over night before a second coat was added
I then went round the car and applied a coat of Blackfire all finish paint protection using the DA and the lake county pad which was left before being buffed using Uber buffing towels.
At the end of the first day
The car was  given 2 coats of the Midnight sun wax leaving approx 60min between each coat again buffed using Uber buffing towels
The plastic trim was dressed using Carpro Dlux which is a cracking product which a little goes a long way and gives a stunning finish.
After this I ceaned the glass and gave them all  2 coats of Autobrite repel and also gave the arches another coat of hyper dressing and dressed the tyres using the Valet pro tyre dressing. Alloys sealed using 2 coats of  Chemical guys Jetseal 109
Exhaust was cleaned up using Autosol metal polish and 00 grade wire wool
And a little beading shot
Offline Guy
« Reply #2 on: 11 May 2012, 12:41 »
lovely work :afro:
Offline Dan J
« Reply #3 on: 11 May 2012, 12:54 »
Nice work butler ;)
The carpro DLUX looks good in the reviews on dw, how you finding it? Application,economical etc?
Offline butler2.8i
« Reply #4 on: 11 May 2012, 15:27 »
Nice work butler ;)
I`m loving it Dan, you use next to nothing on application as a little spreads a long way and gives a nice even coat
Offline dragonfly
« Reply #5 on: 11 May 2012, 19:17 »
Excellent work as always.
Offline murraymint
« Reply #6 on: 11 May 2012, 19:40 »
Awesome work. just wondering, how much would you charge todo this to a car?
O and nice rack  :wink:  :cool: :grin:
josh
Offline Dan J
« Reply #7 on: 11 May 2012, 23:26 »
Nice work butler ;)
cool thanks mate, will get some in when i4detailing has them in stock.
unit looks great aswell, its nice to have somewhere under cover to get on with it isnt it.
cheers Shaun
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #8 on: 12 May 2012, 08:09 »
Very smart  :cool: :drool:
Offline georgeandpeppa
« Reply #9 on: 15 May 2012, 20:25 »
Great job!! Hows the Glossworkz shampoo :wink:
