Author Topic: Faded plastics  (Read 5462 times)
Offline kagero465
Faded plastics
« on: 10 May 2012, 21:43 »
Hey there,
Anyone ever used a heat gun to bring the plastics back up? I've seen it on youtube, looks pretty easy!?
Just sick of back to black. I bought a can of black spray dye the other day, I think it's Auto Glym. Gona have to mask all the paintwork up first, but it sounds pretty good.
Nick
Offline murraymint
Re: Faded plastics
« Reply #1 on: 10 May 2012, 21:46 »
I did it o my Jetta last week
After
Very easy and quick,
josh
Offline kagero465
Re: Faded plastics
« Reply #2 on: 10 May 2012, 21:54 »
Nice!
Is there a certain heat to have the gun at? If it's variable that is.
Offline Loynes
Re: Faded plastics
« Reply #3 on: 10 May 2012, 21:55 »
Did my golf last weekend, get it super clean before you start.  Its bad ass, makes them look sweeeeeeeet
Offline murraymint
Re: Faded plastics
« Reply #4 on: 10 May 2012, 22:07 »
Got my heat gun off eBay for £4, on has one setting, HOT!!!
josh
Offline Loynes
Re: Faded plastics
« Reply #5 on: 10 May 2012, 22:14 »
I did my motorbike plastics with my blow torch!! Works the same but faster and more lethal :evil:
Offline Mongoose
Re: Faded plastics
« Reply #6 on: 10 May 2012, 22:15 »
I have tried this on my plastic trim.
It's best to keep the gun moving. Don't be tempted to leave it in any one position for too long or you can get a bit of a blotchy finish, especially on the bumpers. The results I got were pretty good (but of course are not permanent). I supplement the results by dressing the plastic with tyre blacking foam when washing.
Mongoose
Offline kagero465
Re: Faded plastics
« Reply #7 on: 10 May 2012, 22:18 »
I can't wait that long  :laugh:
Got them in B&Q for £20.
Black plastics tomorrow! I'll stick pics up once I'm done.
[/img]
Offline scottishpedro
Re: Faded plastics
« Reply #8 on: 10 May 2012, 22:43 »
Looks good.  How long should it last?
Offline Mr Blue
Re: Faded plastics
« Reply #9 on: 10 May 2012, 22:53 »
First degrease and clean with isopropyl alcohol. I used a blow torch which is much better than a heat gun but be careful.
I tried the most cheap products from boiled linseed oil to expensive gtechniq c4 permanent trim care but the plastic on one of my bumper was unrecoverable.
Heat gun trick
After trying every product on the market to get that dry look I ended up painting the texture with plastic primer and then a few coats of matt black paint. Matt looks better than satin as it blends in better.
Bumper now looks better than new. Shall get pics when the sun is out.
Autoglym plastic dye does not work! Tried it! Just keep it for the parcel shelf and black carpets.
Gtechniq is the way to go but make sure the plastic is not patchy or it will be sealed like that.
Forver black is like a paint but they call it a dye. Used it on my side trim and have not touched them since.
http://www.elitecarcare.co.uk/forever-black-bumper-and-trim-cleaner-and-reconditioner.php?osCsid=de5d5ca09fe6610e79ce648514f302c1
All the products above can be removed with iso alcohol.
If anyone wants any trim care then let me know.  :evil:
« Last Edit: 10 May 2012, 23:06 by Mr Blue »
