Author Topic: oil pressure switch  (Read 4618 times)
Offline gizmomk3
  • on my way
oil pressure switch
« on: 10 May 2012, 21:26 »
is there any way of fooling the  oil pressure switch iv changed the clock as it was playing up all working now but iv got a oil can light flashing and a loud beep
i think the clock is a gti clock so would i need a gti oil pressure switch???
or can i fool it some how if so how do i do this??
the oil pressure switch is the thing with one wire on it on the top of the engine in line with filter got a black rubber cap on??
Re: oil pressure switch
« Reply #1 on: 10 May 2012, 21:36 »
Try a GTI spec switch, they are different to the lower spec models.
Offline gizmomk3
  • on my way
« Reply #2 on: 10 May 2012, 21:40 »
might have to is there 1 or to  oil pressure switch in mk3 1.6 8v ??
and am i wright is saying it is the small thing with the black rubber cap on????
Offline gizmomk3
  • on my way
« Reply #3 on: 12 May 2012, 19:39 »
Bump
Offline Dan_GTi8v
« Reply #4 on: 13 May 2012, 12:05 »
yes. they are usually colour coded
Offline itavaltalainen
« Reply #5 on: 13 May 2012, 15:04 »
Which engine code do you have? Do you have one or two pressure sensors?
The speedo you have is from a 1.8 75/90hp - not GTI, GTI ones have a different rev counter (the 1000 line is where the 800 is with others).
Oil switch used in the 1.6 (100hp), most 1.8 and 2.0 engines is 056919081E, white 1 pin. I had assumed that you would have a "large" 827 block 1.6?
Offline gizmomk3
  • on my way
« Reply #6 on: 13 May 2012, 17:39 »
Head well scrambeled  :laugh: iv got 1.6 8v how do I find out what size block?? I thing ov got one switch going to try have a look in a bit
« Reply #7 on: 13 May 2012, 18:02 »
What is the engine code?
It's written in the service book, on the cambelt cover or on a sticker on the boot floor?
https://erwin.volkswagen.de/erwin/images/volkswagen/content/fahrzeugdatentraeger_EN.gif
There a a lot of different engines in mk3 Golfs, for each displacement there is approx 4 different engines - with more or less a lot of differences (e.g. there are 4 GTI engines with different injection systems, which is why the code is essential):
http://www.doppel-wobber.de/forum/index.php?page=Info&id=124
Offline gizmomk3
  • on my way
« Reply #8 on: 13 May 2012, 19:34 »
AEE 617255 this the right code??
« Reply #9 on: 13 May 2012, 23:03 »
Think the switches may be different there, need to check prob easiest is to put the 2 AAM pressure switches in, you might only need to swap one, will check and let u know if i find out.
