Author Topic: will 150 bhp turbo fit 130 bhp engine ?  (Read 7992 times)
Offline baggiemad
« on: 10 May 2012, 18:15 »
This has been asked a 100 times i'm sure, apologies but i cant find any threads on here....
My Golf 1.9 tdi 130 bhp turbo needs replacing the actuator rod is partially seized, i have been offered a new 150 bhp one for very good money, will it fit my engine?
its the ASZ engine and a 2002 model
Offline Steve_PD
Re: will 150 bhp turbo fit 130 bhp engine ?
« Reply #1 on: 10 May 2012, 18:35 »
yes. May want the map changed to suit the bigger turbo
Offline Rhyso
« Reply #2 on: 10 May 2012, 19:30 »
It will require mapping :afro:
Offline baggiemad
« Reply #3 on: 10 May 2012, 20:15 »
ok as in straight fit, no modifications?
How much will a remap cost, and does the extra power affect mpg greatly?
Offline Steve_PD
« Reply #4 on: 10 May 2012, 20:23 »
Mpg will be near enough the same. map will cost £200-300 and its a straight fit as the only differences with the 150-130 is the turbo, FMIC and map
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #5 on: 10 May 2012, 22:17 »
@ Steve/Rhyso - Do you know how much bigger? I assume the exducer and inducer (correct names?) are different sizes? The 150 is a vnt17/22 right?
Offline old_n07
« Reply #6 on: 11 May 2012, 07:40 »
The turbo is the same size, it is just the internalls that are up-rated IIRC - the materials used are to a higher spec to withstand more boost and the compressor wheel may be larger.
You won't need a remap unless you wan't extra power as it will run the same as your 130 unit :afro:
« Last Edit: 11 May 2012, 07:48 by old_n07 »
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline old_n07
« Reply #7 on: 11 May 2012, 07:59 »
Turbo for a 130 = GT1749VA
Turbo for a 150 = GT1749VB
The specs are:
VA:- 35 mm intake and 36,5 mm flight
VB:- 37 mm intake and 38,3 mm flight
The VA model off the 130 will have a faster spool up, the only problem is the intake wheel is not meant to go over a set psi range while the VB is designed to support higher boost levels
Offline scarr89
« Reply #8 on: 11 May 2012, 11:48 »
Wow. Good trade knowledge  :wink:
Cheers for the info. Maybe a tad trivial but now I know  :smiley:
