Author Topic: Firewall hole for my amp power cable?  (Read 1193 times)
Offline WhiteGolfMK3
« on: 10 May 2012, 15:04 »
Hey guys,
Sorry if this has already been asked, I tried searching but had no luck. I need some help because I don't know where to feed the power cable through for my amp. I've taken out the glove box but can't see any grommets to push the cable through. Ive tried from the engine bay as well but had no luck. Can you suggest where to push the cable through and where it will come out? Photos would be great but not vital.
Hope you can help,
Thanks,
Pete
Offline b_boy02
Re: Firewall hole for my amp power cable?
« Reply #1 on: 10 May 2012, 15:19 »
Behind the water reservoir is a small circular rubber cover, make a hole in it and stick the wire through (unlike me who lost/broke the rubber cover somehow). Comes out behind the glovebox somewhere, bit fiddly to find but not a problem.
« Reply #2 on: 10 May 2012, 15:41 »
Ok thanks a lot for that, ill give it a go and let you know the result! :)
« Reply #3 on: 10 May 2012, 16:01 »
Thanks man youre a star! Should have my sub wired up today now :)
Offline b_boy02
« Reply #4 on: 10 May 2012, 16:46 »
You're welcome!
