Author Topic: split rim info...  (Read 2263 times)
Offline sam_xr2i
split rim info...
« on: 09 May 2012, 22:46 »
hi guys, i have golf anniversary 16" bbs split rims on my mk3 golf, i want to get them refurbed and polished, is there anything i should know about taking them apart/putting back together as i have never had splitrims before?
cheers
Offline barrym381
Re: split rim info...
« Reply #1 on: 11 May 2012, 21:46 »
use a little heat on the bolts before tryin to remove
Offline sam_xr2i
« Reply #2 on: 14 May 2012, 21:36 »
cheers mate, anything else i should know or any tips guys?
Offline madhead1987
« Reply #3 on: 15 May 2012, 18:20 »
when it comes to slit rims be very careful strippin them because u could snap bolts or f**k the heads of the bolts up also when it comes to refitting the face back on use a tap and tap every hole and wire brush the bolts , also use locktight and tighten them up opposite to oppisite if get me drift for example start with 12 oclcok then 6 then 3 then 9 and so on hope this helps if ou have any probs let me know
Offline sam_xr2i
« Reply #4 on: 15 May 2012, 19:05 »
that great, cheers mate :)
Offline madhead1987
« Reply #5 on: 15 May 2012, 19:15 »
no problem also dont loose any of the bolts put them in a cup or something cuz there like rocking horse turd to get hold of
if you do bugger some up just buy a scrap wheel nd get them ot of that
