Author Topic: Rough running HELP PLEASE  (Read 2995 times)
Offline Willo
« on: 09 May 2012, 21:46 »
Right this is a new problem my 1.4 8 v has developed a problem where she doesn't wanna go very fast seems to be holding back most of the time under load almost seems to be coughing tonight wouldn't go above 65 flat out on the motorway help please slightly concerned  :undecided:
Offline SCO_VAG
  • www.ScottishVag.com
Re: Rough running HELP PLEASE
« Reply #1 on: 10 May 2012, 00:49 »
Could be a number of things, 1st thing I would check is your ECU relay as these like to die from time to time, its located above the fuses and can cause a hole host of issues if faulty.
Offline Willo
« Reply #2 on: 10 May 2012, 15:44 »
How do I check that ?
Offline mrsaunders
« Reply #3 on: 10 May 2012, 16:09 »
Have a drive around then touch it to see if its warm if its cold then get a new one
Offline Willo
« Reply #4 on: 10 May 2012, 16:33 »
Really is it that simple
Offline DUBboi12
« Reply #5 on: 10 May 2012, 17:18 »
Yep it really is :smiley:
Offline Willo
« Reply #6 on: 10 May 2012, 17:36 »
I'll check on my way home from work tonight and come back and let you know the outcome thank you
Offline Dogbot
« Reply #7 on: 10 May 2012, 17:41 »
I had one on my valver that was getting too hot, i mean like almost kettle boiling hot & breaking down under the heat, replaced it & the problem went away...
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #8 on: 10 May 2012, 21:09 »
It's a 1.4, they don't go fast.
Offline Willo
« Reply #9 on: 11 May 2012, 00:34 »
Drove home checked all relays I could feel in the fuse box under the dash as not sure which is the ecu relay they were all cold ????????
