Author Topic: replacing lambda sensor  (Read 1985 times)
Offline bluquarta
« on: 09 May 2012, 15:45 »
how hard is it to replace a lambda on an AGG?
Do you have to take the exhaust off? anyone do me a quick walkthrough?
Offline Dogbot
Re: replacing lambda sensor
« Reply #1 on: 09 May 2012, 16:16 »
you'll be lucky if its not rusted solid dude...... ive not yet done one where i  havent either had to drill out & weld in a new lambda bung, or retap the thread.......
heres how i do it... there may be a million varaiations but this is mine,
before i raise the ramp i unplug the lambda,
raise ramp
unclip the cable & make a note of where it goes for refitting,
thread box spanner, or swan neck ring spanner through cable & undo....... I have the luxury of a lambda socket, however, this does tend to open up an sometimes slip so i prefer the above spanners.......
its at this point you will fight hammer & nail, skin your knuckles, resort to heating & bashing the old lambda untill its free.....
inspect thread, if all is well...
refit new one....
i wish you the best of luck.....
« Last Edit: 09 May 2012, 16:19 by Dogbot »
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 09 May 2012, 18:17 »
As dogbot says can be an absolute pig,but did one on a mk4 not long ago and was a doddle ,good luck
Offline bluquarta
« Reply #3 on: 09 May 2012, 18:34 »
cheers for replies. Hopefully wont be to bad as exhaust system and the lambda are only a year old. Wont buy a cheap one this time, bosch all the way!
Offline Luke1981
« Reply #4 on: 09 May 2012, 19:22 »
Will be worth putting some copper slip on the new one in case you have to take it off again  :smiley:
MK IV GT TDI 150 PD / MKII CADDY SDI
« Reply #5 on: 10 May 2012, 00:11 »
Quick tip, warm the car up first, if it is hot, it will come out much easier, just be carefull
Offline Bellend
« Reply #6 on: 10 May 2012, 00:24 »
Got a genuine one here. Been used for about a month from new. ;)
Another tip if it's tight, as long as you have a new one is just snap the top off the old one and use a deep socket. :wink:
Where all my moneys went.
Offline Bandit127
« Reply #7 on: 10 May 2012, 06:47 »
+1 for this. I thought they HAD to be done at normal operating temp?
Offline javalin
« Reply #8 on: 10 May 2012, 10:09 »
Easy enough - as above, but make sure you have a decent collection of spanners, as its quite a restricted fit under there.
I used crowsfeet to get it loose when I did mine, as they go onto a socket extension and thus don't need the space a spanner does.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline AudiA8Quattro
« Reply #9 on: 10 May 2012, 13:01 »
+2 If you try it cold, damage is likely to occur as the sensor will probably be stuck solid.
