Author Topic: Bearing like whine?  (Read 10011 times)
Offline scottishpedro
Re: Bearing like whine?
« Reply #10 on: 09 May 2012, 13:43 »
Have you checked for play in ur bearings? Also does it get slightly worse if you turn a certain way?
It doesn't seem to get any better/worse when turning left/right, it's only present between 2k-3k revs. The rear bearings have just been done, I will have a look at front ones thanks
« Reply #11 on: 09 May 2012, 13:44 »
Deffo bearing just work out if its front or back . Had the same issue on my mk2 16v about 2 months ago!
How did you work it out?
Offline jezza16v
« Reply #12 on: 09 May 2012, 17:38 »
Diff bearings  :lipsrsealed:?
+1
Or other gearbox related bearing. Suggest you check your gearbox oil level, could be too late now.
« Reply #13 on: 09 May 2012, 20:19 »
Is there a way I can check this?
thanks
« Reply #14 on: 09 May 2012, 20:20 »
+1
I'll check the oil thanks (if I can)
I jacked the car up and there seems to be no abnormal play in the front wheel bearings
Offline lemski
  • 16v
« Reply #15 on: 09 May 2012, 20:36 »
its gearbox then, top oil up but i would say it may be too late now
Offline murraymint
« Reply #16 on: 09 May 2012, 20:37 »
+1
My Jetta has the same sorta sound, checked the oil level in the gear box and was almost dry, new box going in next week
josh
« Reply #17 on: 09 May 2012, 21:08 »
Too late now as in change gearbox? I guess if so it might be worth getting the oil changed and see how it runs for a while?
Thanks for the advice
Pedro
Offline lemski
  • 16v
« Reply #18 on: 09 May 2012, 21:20 »
try oil 1st, depends on how dry it was, might quiten it down. may be 2nd hand box time though buddy
Offline DOA
« Reply #19 on: 09 May 2012, 21:23 »
Out of interest, does it have the same whine in all of the gears, just one, a couple and is it purely engine speed related, doing it at the same revs in whatever gear it does it in? Also, can you repeat the whine with the clutch in or it not in gear?
