Author Topic: Stupid Oil Thingy :s  (Read 1304 times)
Offline Andyfitz
« on: 07 June 2005, 00:24 »
Hey all,
The dub's playing up and pissing me off again  :grin: The problem is the oil light and buzzer keep comming on, now I know this is a common fault, But here's the background of the problem:
It started about 5 months ago, it would come on intermitently at about 5k revs, and when you dropped below about 2000 revs it would turn off again, this then stopped for about a month, then I fitted GTI clocks and no buzzer for about 3 months... untill today  :angry: I thought the fault was with the old clocks, but I must have been wrong  :rolleyes:
Now it comes on when I go about 2000 revs, and unlike before it will not go off without turning ignition off and back on..
Any ideas as to what this might be? am I advised to replace the sensors or check them first some how? it's a 1.3 BTW, any help appreciated! thanks peeps.
Offline hockeylad72
Re: Stupid Oil Thingy :s
« Reply #1 on: 07 June 2005, 09:39 »
I had much the same problem, after replacing both oil pressue switches it was still the same, turned out the clocks were at fault so I replaced the clocks and it's been OK since
It's amazing how annoying that buzzer can be :angry:
hope this is of some help
Offline GTI EDITION (aka LTD)
« Reply #2 on: 07 June 2005, 09:43 »
Always a good idea to get the oil pressure checked to make sure it is just an electrical fault as the strainer on the pickup pipe sometimes get clogged up  :smiley:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline Andyfitz
« Reply #3 on: 07 June 2005, 13:26 »
Yep the buzer is bloody annoying hehe!
I will crack the sump of the fooker later this week and clean out the pickup pipe, And then I have found a new sensor on one of my spare engines so Im gonna try that also, But is there any way to test the sensors? I doubt there is really as that would be to easy!
Cheers guys anyway  :cool:
« Reply #4 on: 07 June 2005, 13:51 »
BTW if you're really sure the oil pressure is fine, remove the buzzer circuit completely.  Its the 'L' shaped circuit board clipped to the speedo :)
If I were you I'd get an oil pressure VDO gauge fitted somewhereso you can keep an eye on the pressure of your mighty 1.3 :grin:
Offline Andyfitz
« Reply #5 on: 07 June 2005, 16:16 »
 :grin:
Im only 18 lol, but wait for the twin carbs to go on the rubilt lump...it will be rather quick of the line :)
