Author Topic: Quick question  (Read 2467 times)
Offline craigus
Quick question
« on: 08 May 2012, 15:29 »
Does anybody know if an xcarlink adaptor can be used as well an a parrot mki9200 on an rcd 300....?? Had a parrot fitted last week and although I'm happy with it the audio quality is a bit poor so was thinking about getting the iPod adaptor if it would also fit in and work aswell as the parrot
Craig
Offline Primus84
Re: Quick question
« Reply #1 on: 08 May 2012, 18:15 »
If the Parrot's audio quality is poor it hasn't been fitted properly.
Offline craigus
Re: Quick question
« Reply #2 on: 08 May 2012, 18:46 »
I believe it has as it was done by source sounds in Sheffield who are an authorised parrot dealer.... It's just at high volume as it doesn't use the stereos amp only it's own have googled it and it seems to be a common thing
Offline Primus84
Re: Quick question
« Reply #3 on: 08 May 2012, 18:47 »
I've got one in mine and it's absolutely fine. Are you streaming music via bluetooth or using the dock connector?
Offline craigus
Re: Quick question
« Reply #4 on: 08 May 2012, 19:43 »
im using a usb stick at moment but when i use iphone its in its dock.... the audio at full sounds a bit poo what audio settings are yours on? do you stream yours of via the dock?
Offline Primus84
Re: Quick question
« Reply #5 on: 08 May 2012, 21:41 »
I'm using the iPhone on the dock connector and it's fine. What type of audio files are you using?
Offline craigus
Re: Quick question
« Reply #6 on: 08 May 2012, 23:05 »
Mp3's on the flash drive and just the normal audio files on iPhone.... It sounds good but just not at full volume lol
Offline craigus
Re: Quick question
« Reply #7 on: 09 May 2012, 21:46 »
so does anybody actually know if i can use the adaptor aswell as parrot??
