Author Topic: Mk1 bit needed  (Read 1099 times)
Offline Redbaron
Mk1 bit needed
« on: 06 June 2005, 22:47 »
Where on earth do i buy the piece of flexi pipe that goes from the primary fuel pump to the boost pump (guessing names)?
Its got a connector on each end that has rotted out, so i need a new one!
VAG still do mk1 bits?
Offline BobbyT
Re: Mk1 bit needed
« Reply #1 on: 07 June 2005, 11:49 »
what engine size is it? vag still do most parts!(i think) i got some radiator hoses off them a few months back!
Offline mr.brown
Re: Mk1 bit needed
« Reply #2 on: 12 June 2005, 17:48 »
If you mean the pipe from the Fuel Pump to the Fuel Accumulator then GSF do them for £35ish.
