Author Topic: Airbag lights and the new MOT rules - new advice. Plus diesel 'cats' not tested.  (Read 1031 times)
Offline Bandit127
VOSA put out new advice on (among other things) airbag lights. "The requirement for an SRS warning light to illuminate has been removed". I do not know if the requirement that originally fitted equipment must be present has changed - I guess it hasn't.
Plus advice that the particle filter on a Diesel (sometimes referred to as the CAT) does not fall under the test for the presence of a catalytic converter. It must still pass emissions tests.
Full FIA harnesses will now pass too.
Full advice sheet here:
http://www.dft.gov.uk/vosa/repository/Special%20Notice%203-12.pdf
